1 - 16 of 16 Posts
Can someone tell me the basic measurements for the rear Caddy Eldorado callipers that everyone suggests that you use in rear D60 disk conversions.
It's a bit hard to find a set here in Oz, but I want to get all the brackets made up. In photos they look nearly the same as the callipers used in late 80's waggys.
Anyone got any good detailed photos of them or can they make some measurements of any for me?
TIA
Rod
Originally posted by Brandon:
<STRONG>bolt pattern is the same, just that the el do's have an e-brake..</STRONG>
Not on the 2 I have. The calipers from the seville are smaller in size so they won't work in 1/2 ton backing plates.
Originally posted by jdjanda:
<STRONG>I have the TSM kit using el-do calipers and the ebrake is non-existent.
Joe</STRONG>
Me too, I never got around to having cables made. These things suck. They're adjusted by the p-brake arm so I have to crawl under there and adjust it every few weeks. I'm just going to throw on a set of 81 K10 calipers I have and mount the p-brake on the transfercase. Anyone know how to get a rotor on an NP205 without buying a new driveshaft?
Originally posted by rocket:
<STRONG>Can someone tell me the basic measurements for the rear Caddy Eldorado callipers that everyone suggests that you use in rear D60 disk conversions.
TIA
Rod</STRONG>
Here you go I think they are on 76-79 Cadillac Eldorado's rears
<IMG width=567 height=365 SRC="http://www.pirate4x4.com/ubb/uploads/76-79 cadi-caliper.jpg">
Originally posted by 66CJdean:
<STRONG>
Not on the 2 I have. The calipers from the seville are smaller in size so they won't work in 1/2 ton backing plates.</STRONG>
right, but the 78-79 eldorado, and I believe deville, do fit the 1/2 ton backing plates
my experiance with these the ebreaks suck anyway, so a line lock and a tire block may be a better way to go <IMG SRC="smilies/biggrin.gif" border="0">
Originally posted by Eric:
<STRONG>76-78 Caddy rear calipers have a 7" pin spacing.
79-85 Caddy rear calipers have a 5.5" pin spacing.</STRONG>
I didn't know what the eldo 78 eldo pin spacing was but I know the 85 seville is 5.5. Warn and many others make weld on bracktes that fit either one.
Originally posted by Grandpa_Jeep:
<STRONG>How thick of a rotor are the caddy calipers designed to work with?</STRONG>
Mine are Mid-80's GM 2wd 1/2 ton truck front rotors if that helps.
Joe
[ 10-29-2001: Message edited by: jdjanda ]
1 - 16 of 16 Posts
