1 - 16 of 16 Posts
hey guys, i got a few questions..
cage is in, the A and i guess it would be the C pillars are already mounted to the frame, plated the frame with 1/4" plate, cut square, welded to the frame in a diamond fashion, the tubes are all welded, and ready to roll (i guess thats litterally eh:smokin: ?)
now i've got 40" MTRs and a low slung truck, so i dont have tons of room between the tire and body, so the b Pillar mount has to be pretty sleek and high.......
i have an idea of how its gonna work, but the tub is not wanting to let me do it..
show your pics....
www.metaltech.com
he has a tie in kit that would do you well.
'll see if i can find a pic of mine.
Found it.
Mark made mine longer to make up for my fenders...
But you get the idea.
Jason M said:
Found it.
Jason- Is there something strange going on with your shock mount in that pic, or am I seeing things? How bout a close up pic?
Considering it is a 5/8" wrench it is not strange...
OnTheSpot said:
My version
had a similar idea.... but that method takes up way too much room for the 40"s to articulate....
my idea was basically that, but the tube was bent on a 90* and the 90 was in the tub, basically like the stock supports, but in tube
You want B or C pillar???
I guess I should also mention that my axle is pushed back. What is your wheel base on 4d's?
:flipoff2:
lol
Discussion Starter · #15 ·
101.... flipped rear springs, and hard mount moved back 1-2 inches.... it's been a while, my brain doesnt remember how much:flipoff2:
i got it mocked up tonight.... my light fell and broke, thus ending my working on the cruiser, i miss my 40x60 shop :( im working in my back yard, but atleast it's MY backyard:cool2:
i'll post pics
i had a similar problem i run 38.5's and only have the springs flipped, so under stuff a lot of options would hit and i didn't want wheel spacers. I cant post pics but if you have a tube bender you can make two opposite bends to push the support over the frame more. It's not as strong as what is seen above but i don't have to hit the cage under stuff either. If i can post on another siter i'll link it here for you.
1 - 16 of 16 Posts
