Here is what I found out about the two frames. Fj55 is 7mm wider in the front, 165mm narrower at the rear and over all, 136 mm shorter. shock towers in different location body mounts different by 10 mm. spring hangers in different locations and the centers to the front and rear axles from the ends of the frames are different. I have the schematics if you want them.
