jstarnes said:
You care to post up a Hydraulic schematic of these valves you speak of?
or are you just gonna talk smack blindly with nothing to back you up?
the reason I ask is because the schematics I have seen say you COULD have a problem, and it MIGHT not track correctly due to the small amount of fluid that would have nowhere to go when the cylinder retracts which would lock up the cylinder which COULD blow the seals depending on what pressure the cylinder was built to handle
Granted in my scenario all the dots would have to connect for this to happen BUT it could happen
OK, so Dougs case shows that a reactive valve does indeed allow reaction with a single ended cylinder. The reason that the reaction was more stiff in one direction had nothing at all to do with any kind of hydro lock because of this being a differential volume cylinder. The only reason for the increased resistance in the one direction is because he was pushing against the bigger side of the piston in that direction , which means that at the pressure required to cause the geroter motor in the orbitrol valve to spin would take about 50% more force acting on the cylinder in that direction.
Thats the key to what you guys are not seeing with your claims of incompatability between load reaction and unbalanced cylinders. Regardless of whether you connect a balanced cylinder or an unbalanced cylinder to a load reactive orbitrol , when a great enough force is applied to the cylinder the gerotor is going to spin. When the geroter spins it opens up the working ports to the T port reguardless of whether the steering valve is in a neutral position or not(unlike the P port which requires input). When there is a positive or negative pressure between the working ports such as there is when running an unbalanced cylinder , this is compensated for by the opening to the T port.
The reason I wait this long to post this, and not post it with a diagram , is because I asked Danfoss engineers about this quite a while back, just to make sure that I was not doing anything without their reccomendation. They said , "NO PROBLEM" , and instead of answering all of my questions over the phone they answered them by sending me a Saur Danfoss technical bulletin that spoke specifically of this.
Well...... that was nearly 2 years ago, and I have moved in that time period. I can not find that technical bulletin with the diagram , so the other day I spoke with some Danfoss engineers again to see if they could send me that technical bulletin . They are very busy , and I have not heard back from them yet , but I am sure they will come though shortly.
Anyway... in the meantime I am being posted about in such a way as to be made to look an ass because of someones apparent personal grudge , and I can not wait for engineers in Denmark for "back up".
Sorry but this is NOT a problem , a small ammount of fluid with nowhere to go ISN'T a reality , and it NEVER WILL cause you to "blow the seals" in a steering cylinder.
Sean
blind...
