1 - 14 of 14 Posts
over memorial day weekend We cut the IFS off and went solid axle on the truck.... I used the All-pro front hanger and shackle, 2.5 inch YJ springs and crossover steering in the front. The rear are 63" chevys with the overload leaf removed and a double shackle on the backside....there are no shocks at the moment
The axle
<IMG width=700 height=491 SRC="http://www.pirate4x4.com/ubb/uploads/0100.jpg">
The last of the pieces I was awating before the swap(started that night/ all-pro stuff)
<IMG width=700 height=491 SRC="http://www.pirate4x4.com/ubb/uploads/0101.jpg">
new rear srping hanger getting welded on
<IMG width=700 height=491 SRC="http://www.pirate4x4.com/ubb/uploads/0102.jpg">
IFS getting cut off
<IMG width=700 height=491 SRC="http://www.pirate4x4.com/ubb/uploads/0103.jpg">
And the anticipated moment...the mid-air fall <IMG SRC="smilies/biggrin.gif" border="0">
<IMG width=700 height=491 SRC="http://www.pirate4x4.com/ubb/uploads/0104.jpg">
nother pic
<IMG width=700 height=491 SRC="http://www.pirate4x4.com/ubb/uploads/0105.jpg">
Discussion Starter · #2 ·
more pics
our beloved mini sledge broke
<IMG width=700 height=491 SRC="http://www.pirate4x4.com/ubb/uploads/0106.jpg">
spring hung
<IMG width=700 height=491 SRC="http://www.pirate4x4.com/ubb/uploads/0107.jpg">
Axle in place and bolted up
<IMG width=700 height=491 SRC="http://www.pirate4x4.com/ubb/uploads/0108.jpg">
on the ground finally
<IMG width=700 height=491 SRC="http://www.pirate4x4.com/ubb/uploads/0109.jpg">
front and back shot...need blocks in the rear
<IMG width=700 height=491 SRC="http://www.pirate4x4.com/ubb/uploads/0110.jpg">
and my weak ass pose....The only place I know off to test this stuff....need to find a better place
<IMG width=700 height=491 SRC="http://www.pirate4x4.com/ubb/uploads/0111.jpg">
well there it is....If a couple of high school kids with a torch and an arc welder can do it...so can you
Originally posted by xextr3m3:
<STRONG>
</STRONG>
Buy some longer jackstands!! <IMG SRC="smilies/eek.gif" border="0">
Other than that is looks good. Now it is time to go test it out.
I did my Tacoma SAS last weekend using Chevys out back and AllPro 5" up front. My rear is about 6" lower than the front -and- I even used a 4" drop hangar in the rear along with a 6" shackle. I'm going with a 10" shackle and a 2" block this weekend.
Wicked Raciest !
Originally posted by Dirty Harry:
<STRONG>Buy some longer jackstands!! <IMG SRC="smilies/eek.gif" border="0">
Now it is time to go test it out.</STRONG>
Go get it!! Looks great for a couple of High School kids.
Now a word of safety advice, Never use bricks, concrete blocks, rocks under jack stands, they can break, shatter real quick. Find a construction site and there scrap pile and get some wooden header materal 4 x 10, 4 x 12 and use that to put your stands on.
Discussion Starter · #12 ·
thanks guys.....I still have tp put my front driveshaft in <IMG SRC="smilies/smile.gif" border="0">
Hey those brick held up pretty well.....I think im gunna go buy some 12 ton stands from harbor frieght now since I sold the IFS
....All-pro double arm....
[ 09-07-2001: Message edited by: xextr3m3 ]
Wicked Raciest !
<STRONG>
[ 09-07-2001: Message edited by: xextr3m3 ]</STRONG>
The problem is that you never know when they are going to decide to let go. I am speaking from experence, luckly I was not under the 55 Chevy when it let go even though it still had it's tires and wheels on it. It only sat 4 1/2" off the ground in the front and when the bricks shattered the front x-member bounced off the drive way and chipped it!!!! <IMG SRC="smilies/eek.gif" border="0"> <IMG SRC="smilies/eek.gif" border="0">
[ 09-08-2001: Message edited by: UN-XTREME OPP'S ]
Originally posted by BigBadBob:
<STRONG>I did my Tacoma SAS last weekend using Chevys out back and AllPro 5" up front. My rear is about 6" lower than the front -and- I even used a 4" drop hangar in the rear along with a 6" shackle. I'm going with a 10" shackle and a 2" block this weekend.</STRONG>
wait until the all pros settle, bob! they go down about 2 inches or so after the first 1500 miles and/or a trail run or two. <IMG SRC="smilies/beer.gif" border="0">
1 - 14 of 14 Posts
