Krylon.. said:
Do you guys know an online source for where I could read through code for Ohio? I have been searching and coming up empty handed... I can find plumbing and mechanical, but nothing on electrical.
I've never found an NEC online either (at least not without paying). It's not at all like the other NFPA code books. I have seen it on CD, but never gotten it. Unfortunately, the cheapest I've seen even a soft cover book for is $65. CHeck with your local library, or coffee it up at the Barnes & Noble while reading up on code (take a notepad, or a pocket full of dimes for copies)
My guess is that you will not be able to check it out from the library, so the dimes still hold true (it would be considered a reference book)
Another idea is to check with your governing municipality. The ones who establish the local building codes (city, county, etc.) Some communities will loan you a book to study, and allow you to take a test for a 'homeowners' permit, still subject to inspection if you are doing a significant upgrade to your residence.
Just a couple of ideas.
The NEC is updated every 3 years, and some municipalities aren't too quick at adopting the latest version. Around here, there are still a couple of towns working off of the 1996 NEC. Find out which version your municipality uses and study up on that one.
Good Luck!
