1 - 20 of 51 Posts
I am planning to replace my old 3.5 V8 with a 4.6. Ultimately I will fit the Thor injection manifold with a Megasquirt ECU but as a first stage I want to investigate fitting the old 3.5 Zenith Stromberg CD175 carbs to the 4.6.
For sure larger jets etc will be required but I cannot find anywhere what the maximum size cylinder/size the twin carbs can handle.
The largest engine I can find that has these carbs fitted as twins is the Jag 4.2 6 cylinder (350cc cylinder volume). While a 6 cylinder 2.6l landrover engine with a single carb has to provide enough air for a 433cc cylinder volume.
A 4.6 V8 only has a cylinder volume of 287cc so in theory the carbs suitably jetted should be able to provide enough air.
So any one put the CD175s on a 4.6 V8 and are there any issues? Likewise what alternative carbs are there that are suitable for offroad, steep slope use?
Thanks
Garry
Hi,
I used SU HIF6 on my 3.9 with BDR needles - went well. It went even better with BBC needles!
Avoid Strombergs, the diaphragms don't seem to like modern petrol and soon fail.
Discussion Starter #4
Thanks - but I am talking a 4.6 not a 3.9 and I know strombergs work fine on a 3.9. I have not had any issues running my stombergs (I have them on two different vehicles (a total of 6 carbs) on 91 ron fuel - however I do not use any fuel that had ethanol in it - hence I do not buy BP fuels as it has ethanol in it.
Cheers
Garry
Discussion Starter #6
Why what??
I am wanting to put in a 4.6 to replace my carb 3.5. I have the thor injection manifold for the 4.6 but a 4.6 ECU does not work outside its donor vehicle so I will need something like megasquirt but with everything that is needed is very expensive. So I am wanting to put the 3.5 carbs on until I go to part 2 of the project later and sort the injection.
I just do not know if the 3.5 carbs can handle the 4.6 airflow but cannot find anyone has used them.
Cheers
Garry
Why what??
Cheers
Garry
IF you were to use the GEMS EMS ECU you would not have this problem and the wiring harness and ECU ought to be available dirt cheap.
I can see absolutely no justification for what you are suggesting given the ease of doing it right and welcoming in the 21st century.
^^^^^^ This
Or this Self Tuning EZ-EFI Fuelairspark.com
Or This https://www.holley.com/products/fuel_systems/fuel_injection/terminator_efi/
Or This https://www.holley.com/products/fuel_systems/carburetors/avenger/off-road_truck_avenger/parts/0-90670
Would be way better than zeniths or MegaSquirt.
MegaSquirt is old used up technology do as PT says and try something from this century.
Someone has to point out the obvious...
1999 was last century
GEMS is definitely the way to go. There are 3 obstacles as I see it. 1. You have to kiss someone's ass and probably pay a few hundred to get the alarm disabled
2. The p1317 abs code. Without functioning abs the check engine light goes on. An always on light is just as worthless as no light
3. Whoever knows how to tune them doesn't share any info. Mail order tuning sucks
I don't know about this. If you search, you'll find it
Curious, hasn't been a problem with those I've built.
I'm working on it, but the curve is gonna be flat for a long time as I need to get good with 14CUx before I get into the GEMS stuff. I do have chips purchased and have at least been able to communicate with the individual chips on a rudimentary basis, have changed some data points but there just isn't much documentation out there on the GEMS EMS.
please try a quick search I know the info is out there :shaking: because I put it out there but you must look
oh please for the love of all things rover pls just do a search for the info you seek instead of just running your trap ....hugs and kisses AFI
well, there wasn't really any question, so I'm not sure what to search for
I know of no way to ditch the 10AS without a rover specific scan tool, never really looked in to it since I have no intention of disabling the alarm in my vehicle, but maybe you want to help out the original author of this thread who does not have an alarm or even a wiring harness and tell him how to convert to GEMS without an alarm rather than a vague "the truth is out there" response.
Some ecu calibrations seem to ignore the p1317 while others don't. My 97 D1 is one of those. have you found away to completely remove the wabco unit without triggering a fault on all gems ecm calibrations?
And tuning... those who know don't want to share. It's a shame. An international mail order tune should not cost what it does. If you know something about tuning the eproms with real useful information like addresses and checksum information I know you haven't posted it, its been a routine search of mine for a long time. I was hoping someone would figure it out before I had to.
Discussion Starter #19 (Edited)
The only difference is the CkPS mount and flywheel
And the inlet system, injectors and is sequential - is Gems compatible with the Thor injection system.
But we are off topic - as I said the injection system is phase 2 of the overall project.
I want to use what I have now and get the vehicle on the road now, ideally on rejetted carbs and when the engine is in the vehicle and running - phase 2 will start. If I wait to sort an injection and ignition system the vehicle will not get back on the road in the foreseeable future.
On the Holly carb use - I have access to a modified manifold with a holly fitted but even when modified they are not satisfactory in very steep climbs due to fuel starvation. Fine on a street driver but not so much for steep offroad use.
So can we leave the injection discussion to a later thread and continue with the carb discussion.
Thanks
Fit it with a pair of SU HIF6 or HIF 44 carburetters.
Why?
1. There are at least an order of magnitude more needle profiles for SU carburetters than for Strombergs. This makes it far easier to get the fuelling correct for the 4.6 (which was why I explained about running my 3.9 on these).
2. There is no diaphragm to split, irrespective of what petrol you run through them.
3. Even backward thinking Land-Rover ditched Strombergs in favour of SU's
1 - 20 of 51 Posts
