Greetings all, I was wondering what degree shims I need to correct the caster angle on my 84 p/u. It has a set of 5" skyjacker springs and stock shackles. There are no degree shims at all under the spring pack. Its has decent steering response but it wanders just a little bit. The torque bar is still intact and the bushings are not worn out. Also I disassembled, inspected and greased the draglink in hopes that it was causing the slight play in the steering but it wasnt. The toe in may be out a little bit but I dont thing thats the whole problem. I was hoping to install a little bit longer front shackles to help it flex better but I dont want to accentuate the problem that I already have. If anyone knows the correct toe in and degree shim values please let me know. Thanks fer all yer time.
-j-rOd
-j-rOd
