1 - 8 of 8 Posts
Ok so im running allpro hanger and shackles and 2.5 inch YJ's in the front....Looks to be about stock pinion angle
I need to rotate the pinion up because there it too much angle on the diff side of the front shaft and it almost bottoms out the joint while at rest.
what is the max I can rotate the pinion? What degree shims should I use....can I shim it?
Be careful when you change the front pinion angle. Now you are messing with the caster? Or is it camber. Anyway when changing the pinion angle in the front sometimes you must turn the knuckles at the same time. If you tilt the pinion up then the 2 to 6 degrees caster top leaning back, will get eliminated and the stearing geometry goes bad. Some one with proper terms reply please.
dude....I would love to do all of that but I am at this point
<IMG width=700 height=491 SRC="http://www.pirate4x4.com/ubb/uploads/01120.jpg">
+ shocks and front driveline
and I have to drive it to school(2 schools) every day
1 - 8 of 8 Posts
