1 - 3 of 3 Posts
In a couple weeks I am SASing my Tacoma, since my truck won't fit in the garage, I have to do the swap on the driveway. The driveway isn't that much of a slant but its pretty significant. Do I have to do anything different when setting the castor of the axle? Thanks!:flipoff2:
Banned
Put the axle in, then slowly and carefully drive it to a flat section of road. then check caster.
Otherwise, get a digital angle meter, get the angle of your driveway, and accommadate :rolleyes:
Id just buy a cheap angle finder, find a line on your truck that level the way you like, like a spot on the frame, rails whatever. Then when you have your axle under with weight on it, use that line again as a zero and put your 5 or whatever degrees of castor in.
1 - 3 of 3 Posts
