1 - 8 of 8 Posts
I know this might not be the place to post this type of question, but all start hear anyway, sence the problem is in a toyota. when i key up the mike only when the sterio is on, i get back feed going through the amp and sterio. i tried moving the antenna cable away from the rca cables running to the amp, and it still does it. any ideas. any ideas on what is going on.
I stand by my suggestion that you check your grounding. The CB radio chassis, the antenna, and the ground wire. What type of antenna cable are you running? I run RG-8 since it has the thicker insulation and the stranded inner and outer conductors. But then again I used to be a Navy Radioman. A linear? Really?
Banned
Do they just hand out Ham licenses these days ? When I got mine twenty years ago we had to learn about RF. As for a CB I ran an export and a Texas Star linear 600w amp. I put the amp in the trunk and kept the Coax between the amp and antenna really short. No problem.
1 - 8 of 8 Posts
