will an 83 22re long block from a celica swap in to an 85w/22re?
so far i have found out the deck height is different and water pump also, if you use the correct water pump and front cover off of the 83 motor, will it all come together? also i hear that the exhaust bolt pattern is different, but you don't have to drill, just relocate studs, is this true. if you use the 83 lower plenum and the upper 85 will that work for the intake side? thanks
