1 - 8 of 8 Posts
I've done a search, and couldn't find any information on the best bushings to use for a TTB.
I did a cut & turn of the beams, to equate to a 5" lift, and am presently in the process of reinforcing everything. I don't want to go uniball, or anything too fancy, I just don't think I need that. Just curious on the type of bushing which has worked the best for longevity and performance?
If you're looking for a compliant ride and longevity, go with the factory style rubber bushings. I'm sure others will say go urethane, but if you think of the hundreds of thousands of trucks with rubber pivot bushings and the amount of miles on each... you gotta admit that they do last a long time.
not when twising the suspension, the stock bushings are ment for road use and mild off-road. ive tried running stock rubber bushings and i kill them from twisting all the time
1 - 8 of 8 Posts
