1 - 1 of 1 Posts
i just picked up a power steering gear box for my TJ, i did the durango swap, everything went smooth after i broke the 1st pitman arm puller, i get box done fill reservoir and found this one leaks worse then my old one, so i take it back, get another new durango box and put it on, no leaks but it isn't centered, now i know the pitman arm can only go on one way and same with steering shaft so how do i adjust it? what i mean by not centered is it takes one an a third turns from"center" to full lock on left side and one and 2/3s from "center" to full right lock, there is an adjustment Allen head bolt on top but i wana make sure that will work 1st, and yes when driving straight the steering wheel is straight, this is really hurting my full left turns, although right turns on a dime
1 - 1 of 1 Posts
