1 - 13 of 13 Posts
Weld says their rims are forged T6-6061 billet AL. Centerline says theirs are "rotary forged" and (on their www site anyway) dont seem to say what AL alloy they use. Question is, which are better/stronger rims? Does Weld use a different forging process? if so, is it fundamentally better/worse? or just different?
j
i wanna run big tires for my drivetrain and to help my axles withstand the abuse I wanna run a very light wheel/tire combo. I'm gonna run Iroks and some kind of forged AL rim. I dont have the $ for spendy rims at the moment, but this is a long term project, so its all good. :D
AFA polishing goes, fawk it... if they gimme too much trouble I'll just paint em flat black. lol!
j
I don't think you are going to save much weight with either welds or center lines, both of these companies build heavy duty wheels and they use some thick ass aluminum. I was shocked at how much they weighed! I do know 2 people who have been running center lines because they didnt want to spend the cash on welds and both sets of wheels have been beat up pretty damn good and are still holding up great. I would run Center Lines with out any worries after seeing how gouged out their wheels are and they are still straight and seem to hold a bead very well.
i'll have to get some specific #s I guess... if there isnt much weight savings at all, why not just run cast rims. If they are beadlocks, the little lip that tends to get broken off on rocks will be reinforced anyway. The whole rig is gonna weigh under 2500lbs, so I dont need a 3500lb per wheel load capability or anything...
j
NE-RokToy said:
If your going beadlocks I don't see why cast rims wouldnt work. Like you said you don't need a super HD wheel and you are reinforcing/replacing the weakest part of the wheel.
Beadlocks only reinforce the outer wheel lip, the inner is still suseptable to cracking/bending. I bent the inner lip on my steel wheel last time at Paragon, at least with steel it can be easily fixed with a hammer.
Wouldn't cast aluminum rims prove to be a hassle to weld on the inner ring for bead locks? I'm thinking melt city. And doesn't cast anything have less strength to handle a thread tap which would make stripping beadlock bolts easier?
Jekbrown, you might first talk to folks who covert wheels to beadlocks to check if cast AL would take a beadlock ring well. Unless you've found such a wheel pre-made.
And don't cast AL wheels crack when stressed instead of just bending like forged AL or steel? IIRC, such cracks are not field fixable.
Discussion Starter · #13 ·
yeah, Im not sure about the beadlock conversion... but Trailreadys and Walker Evans AL beadlocks are cast... aren't they? Do they even make their own wheels or are they just adding beadlock capability to someone elses?
j
1 - 13 of 13 Posts
