1 - 4 of 4 Posts
is there any spring shop anywhere in central IL. and how much more lift can you get from stock K30 packs? if there is a shop around here can they re-arch spring packs so could get around 4/3" height lift? F/R ? thx
i have found this so far:
http://heritagewelding.com/order_springs.php
anyone know anything about this place? or is this not the right place or way to go about making getting lift springs,. from my stockers?
St. Louis spring can make whatever you want. I had them make some new main leaves for my s10 axle swap. I set it up with wagoner lift springs, needed a little more shackle angle, so I had them make leaves that were 2 inches longer, 1/2 inch more arch, and the center pin 1/8 inch farther forward. They make springs in the morning, I think they said they shut the forge down noonish. Ask them to show you around.
LEAF SPRING SUSPENSION
Burke Spring in Danville is a good shop. I'm pretty sure they will discourage your plan though. My understanding is that old stock springs will only hold the arch for a little while and then will sag back unless you take them apart, heat, arch and re-temper them. It would be cheaper to order a set of lift springs...
1 - 4 of 4 Posts
