I thought I would ask ya'll to see what ya think. Here's the scenario: '88 Range Rover originally fitted with a 3 wire, 65 amp Lucas alternator. Replaced Lucas with Bosch truck alternator from Volvo truck (120 amp rating). I have a red top Optima for a battery. Power draining accessories include: H 3000 lights, W 10,000 lb winch, H4 55/80 watt headlights. Anytime I turn on something high amperage the truck starts to miss or surge and then(usually) slowly recovers. This past weekend I had to winch out a badly stuck IH Scout and it about killed my engine when under load, even with the engine reved up to 2500 rpm. Took the alternator to a shop had them put it on the machine. At 3500 rpm the alternator would put out 142 amps. They said I need dual batteries (which I want anyway). I'm afraid that won't fix my problem. I can be running down the road with lights off (daytime of course) switch on the AC and the truck will stumble for a second. Seeing how that is a "stock" item I don't think Dual batteries will help. So, today I took the truck to another local shop and he put a tester at the wire coming from the alternator With the lights on etc. it was putting out 65 amps, tap the winch remote, it would jump to over 100 amps. He then put it at the battery and said it was only taking about 3 -6 amps. He said the wiring could be bad or the battery is bad. Do Optimas go bad just like that? It still starts fine. Any suggestions? I went over to a local electronic supply place and bought some 6 GA wire. Iplan to replace the wire from the alternator->starter->battery. Any help would be appreciated.
