1 - 18 of 18 Posts
Hello can anyboddy help me regarding to if the chassis is the same on the Sierra/samurai with plate spring and the Sierra/samurai that has ciolsprings?
Do anyboody now if theres any pictures on the net or a page where I can find out??
Questions for you.
We never got coil sprung Samurai/Sierras in the U.S. so I was
hoping you could answer a few questions.I believe the front
differential is high pinion,what are the gear ratios available?
Also,do you know what the spline count is for the front inner
axle shafts?
here you go Tommy O
http://www.off-road.com/suzuki/samurai/97sierra.htm
Mine used 3.909 gears standard , i could go out and look at the front diff pinion if it wasnt so dark out. i think its similiar to the new Jimny axle and could be wider than a widetrack samuri axle , it uses the old vitara rims as standard . I dont know why somebody cant send some of these stateside .
TommyO said:
what kind of difrents are there
I´m going from memory here, so I likely won´t remember tehm all.
t-case supports
spring and shock mounts
front bumper mount
rear tub cross member
front clip mounting
brake proportional valve mounting
HTH
Re: Questions for you.
axle shafts?
Yes, it´s a the front dif is high pinion, revese cut. The ratio is 3.91. I don´t remember the inner spline count, but IIRC it´s exactly the same as the older Samurais.
I´ve got both of my original axles gathering dust in my boat shed. That front high pinion was sweet, but I wanted more beef, so I went to Danas.......
If you´re refering to only the front diffs, yeah, there´s prolly some way to send them Stateside. If you´re talking about the newer Samurai as an entire vehicle, not likely......
Chrysler and Consumer Reports have seen to that.......:p
high pinion
Well Bill,if you ever decide to come north to the States,bring
that front diff.I'll buy it off you.Judging by the amount of dope
and illegal aliens that cross the border it shouldn't be to hard
to smuggle a Samurai chunk.
what are you saying ...nobody could just buy one and get it sent there , we buy thousands of secondhand corvettes, camaros and mustangs from there, bout time you guys bought something back.... think of the benefits no rust , coils to play with , probably be better off buying a Jimny though (we dont get the Sierra here anymore), to get power steering , longer wheelbase , efi , etc
No sense importing what you can't drive on the highway (legally). US vehicle saftey regs are among the strictest in the world in that if the vehicle doesn't pass full certification it can't be driven on the road.
Now, don't confuse this with strict in the sense that the safety concerns are paramount - just that you have to jump through the NHTSA/DOT hoops to get it on the road.
.ca is the same way.
[email protected]
Re: high pinion
It could be shipped. However, I have no idea as to how much it would cost.
BTW, the rear R&P would also have to go together, as the ratio (3,91) is different that that of the older Sams........
[email protected]
Not saying anyone should do anything illegal of course....
You can do what alot of the mini cooper guys have done for years. Bring a vehicle into the country in a few different pieces. This way its just 'replacement parts'. Once here, reassemble and accidentally mix up the paperwork on it and another Samurai title you might have laying around. Sometimes those VIN tags can fall off too. You can always reattach them with a pop-rivoter.
Your aftermarket modification pieces will be highly limited in North America though, even items as basic as lockers.
1 - 18 of 18 Posts
