1 - 12 of 12 Posts
Trail Tampon
check my 4 link numbers (i think i got it)
this is my first go at it so flame away:flipoff2:
the ride is a xj with 39.5 iroks and rear 60.
we took all the numbers from a 8.25 and 36 so i adjusted as best i could
static anti squat looks good but the droop and bump numbers are kinda scary... can they change???
i also cant find the rear steer numbers???
what do you think?
Trail Tampon
i was shooting for a low as #
there are too many opinions flying around.
the rig will be mostly crawling and hill climbs, no planned jumps or hwy speeds
raise the rear mounting height of your uppers or lower the forward mounting point of your uppers.
Bring the instant center down.
and just post the file so if someone chooses to spend a few minutes and help they don't have to spend an hour inputting all your data.
Trail Tampon
i have adjustable mounts on the uppers on the frame side and all calculations are done at the highest point. the lowest point is 4" lower
the last post with the uppers in the lowest point will give a 110% to 54%
no idea how to post this file though... any ideas???
You don't have the solver add-in installed and it is not calculating the travel. Look at the Length0-Length1 box. It should be 0. If it is not it isn't calculating.
Trail Tampon
This is a good final revision. I finally figured out the travel calculator. And I think this is the best I can do.
All travel numbers are 4” up and 10” down
Anyway at the top position on the frame side upper mounts:
Static anti squat= 76
Droop anti squat=85
Bump anti squat= 74
Max pinion angle deflection= -4 degrees
second position on the frame side upper mounts:
Static anti squat= 84
Droop anti squat=90
Bump anti squat= 83
Max pinion angle deflection= -5.3 degrees
Third position on the frame side upper mounts:
Static anti squat= 91
Droop anti squat=95
Bump anti squat= 92
Max pinion angle deflection= -6.5 degrees
bottom position on the frame side upper mounts:
Static anti squat= 99
Droop anti squat=99
Bump anti squat= 101
Max pinion angle deflection= -7.7 degrees
1 - 12 of 12 Posts
