1 - 9 of 9 Posts
I found a mid to late 70's Chevy K20 longbed 4x4 in a wrecking yard. The drivetrain is all there and untouched. I know the owner of the yard and he will give me a deal on the axles. I'm not an expert so I'm unsure of what they are. The rear is an 8-lug 14 bolt FF, but the front I have no clue at all. It's an 8-lug axle with knuckles, 10 bolt cover and the diff looks a little bigger that a few dana 44's I've seen(I think). It doesn't look like the newer style 10 bolt front axle. So is it a 8-lug 3/4 ton dana 44 or possibly a D60? Any clue as what the pair would be worth??? I could probably score all the steering and drivelines as well. Thanks in advance.
As far as price goes, some of the value will depend on the gear ratio. Let's assume that it is a D44 (most likely) and a 14 bolt. If they are stuffed with 4.10's, I would give in the neighborhood of 300 bucks if everything is there and useable (brakes, hubs, etc.). Higher the gears, the less I would give.
1 - 9 of 9 Posts
