321 - 339 of 339 Posts
83 k5 lt1 t400 203/205 d60/14b
Fuel tank is back in, I put a sump in the bottom so the in tank pump sits below the bottom. Fuel tank is a 30 gallon out of a Freightliner m2. Axles are back under it too, time to start on the brakes.
I had to pull one head back off, had a lifter sticking and got the rest of the trunnions installed. Now just have to wait on a new lifter another head gasket and head bolts to show up.
Motor is a gen 3 408 stroker with ls3 heads 10:1 compression btr ls3 stage 1 cam.
E-Locker or Bust!
That's purdy!
I picked up your old K5 minus axles last night. Going to move the trans and doubler over to my K5.
Wheel Tire Vehicle Automotive tire Motor vehicle
Nice! Lots of good parts. Psc hydro steering too. I’m looking forward to seeing your k5 build. Crazy when I found c3 all I was looking for was some bump stops for the front end of that😆
Thanks! I already have PSC Hydro assist on mine, so selling the assist of of this.
Chassis and engine are going a buddy, he's going to slap axles under it and a different trans/t-case and run it.
Th400 and doubler are going into my build.
Finally got the motor mocked up. Had to cut off the old motor mounts and have to get a shallow oil pan .
