1 - 7 of 7 Posts
I'm putting a Chevy d60 from a duallie under my '89 dodge. I bought superlift's 5.5 inch susp. lift and skyjacker's adjustable drag link. When I bought the stuff I was going to use the half ton axles. With the d60, the steering arm hole for the drag link to connect to is way too big for skyjacker's drag link end. What can I do to fix this? Crossover? aftermarket steering arm? Did the D60 ever come with a steering arm that uses the D44 size drag link end?
Thanks guys.
Go to a good parts store (not a chain store), and have them look in the Moog or TRW catalog and try to find a TRE that has the same thread as your small end and the large taper of the 1 ton end. I am pretty sure there is something available.
Travis..
Thanks Skidrow.
I'll see if I can get it to you tonight. I'm not sure if I have a thread pitch guage. I may be able to call skyjacker and look it up. I'm using their drag link. Their end has a much larger diameter shank that any OEM end I've seen. Hopefully you can find one with the same diameter shank and thread pitch and has a larger GM taper.
I'll measure it tonight and post again.
1 - 7 of 7 Posts
