1 - 1 of 2 Posts
Administrator
Discussion Starter #1 (Edited by Moderator)
[*]Chevy Silverado 2500HD by BillaVista - Pirate4x4x.com
pirate4x4-tech2.gif 2007 Chevy Silverado 2500HD LS 4x4 CCSBSpecs & Description
By Bill "BillaVista" AnsellPhotography: Bill Ansell Copyright 2007 - Bill Ansell (click any pic to enlarge)
2007 Chevy Silverado 2500HD LS 4x4 CCSB - Specs and tech Data brochure_tn.jpg
This information is unashamedly all about my particular truck. Much of the information will also be applicable to many other trucks, even if they aren't the exact same year, model, configuration, or trim level as my truck. I can't, however, cover all the info and options for all trucks, even just the 07's or just the 2500HD's. If you need more specific information about a different truck, see the "references" section at the end of this article.
My truck is officially known as:
2007 Chevrolet Silverado (Classic) 2500HD (K25743) LS Crew Cab Standard Box 4WD 1SK Package
That's quite a mouthful of a name! It breaks down like this:
2007 Chevrolet Silverado - Year, make, and model (obvious!)(Classic) - Denotes the older body style of the two versions of Silverado that were produced as 2007 models.2500HD - Chevy's notation for Heavy Duty 3/4 ton pickup truck(K25743) - GM model number for Crew Cab Standard Bed 2500HD 4x4LS - The trim level (LS is the mid-level, between Base and LT)Crew Cab - Four full doorsStandard Box - The box is 6'6" ( a short-box is 5'8" and a long-box is 8' long)4WD - Four Wheel Drive1SK Package - sub-set of the trim level, denotes a standardized set of options.
The line of trucks to which my truck belongs is known as the GMT800 series. Covering 1999-2007 they are also more commonly known as NBS, or "New Body Style", trucks. Of course, now that the Silverado has been redesigned for 2007.5+ (the GMT900 series trucks) it becomes less convenient to refer to the 99-07 trucks as NBS, unless we want to call the 2007.5+ trucks NNBS!
The Truck - Basic Specs
2007 Silverado 2500HD LS, 4WD, 4-door Crew Cab, Standard Box
EngineVortec 6000 6.0LV-8 (LQ4), OHV, Sequential multi-point electronic fuel injection
Horsepower: 300 hp @ 4,400 rpm. Torque: 360 lb.-ft. @ 4,000 rpm.
TransmissionHeavy-duty Hydra-Matic 4L80-E four-speed automatic transmission
Transfer CaseElectronic shift-on-the-fly 2-speed NP263HD Transfer Case
Front AxleAAM 925 - 9.25" Ring Gear Independent Front Axle, 4.10 PowerDense gears, Torque capacity 4647 ft lbs.
Rear AxleAAM 1050 - 10.5" Ring Gear 14-bolt full-float rear axle, 4.10 PowerDense gears, Eaton mechanical locking differential (GM RPO Code G80 - Differential, locking, heavy-duty, rear), Torque capacity 6232 ft lbs.
SuspensionLong- and short-arm independent front torsion bar suspension
Semi-elliptic 2-stage multileaf spring rear suspension
SteeringIntegral power recirculating-ball steering
BrakesHydroboost power 4-wheel disc brakes, 4-wheel ABS
Wheels8-bolt 16.0" x 6.50" Aluminum Wheels
TiresLT245/75R16E Bridgestone V-steel Black Wall All Season Steel Belted Radials
Dimensions (inches)Weights (lbs)
Wheelbase
153GVWR9200
Overall Length237.3Curb Weight5883
Overall Width79.7Payload3317
Overall Height77.4GAWR - Front4670
Track Width F/R68.6 / 66.0GAWR - Rear6084
Ground Clearance F/R8.9 / 7.4Max Tow - Weight Carrying7500
Max Tow - Weight Distribution9800
Max Tow - Fifth Wheel9800
GCWR16000
Features
InteriorExterior
Power Door Locks Power Mirrors Power Windows Power Drivers Seat Seats 6 Dual Zone Climate Control with AC Auto-dim Rear View Mirror with Compass and Temperature Cruise Control In-dash AM/FM/CD Steering Wheel Audio Controls Full Gauges - speedometer, tachometer, voltmeter, coolant temperature, transmission temperature, oil pressure, fuel gauge, odometer, trip odometer and engine hour meter Front, Custom cloth, 40/20/40 split-bench Rear, 60/40 split fold-down seatFully Galvanized Steel Body Four Doors Tinted Glass Fog Lights Off-road Skid Plates Tubular Step Bars Fender Flares Variable Wipers Tow Hooks - Front HD Trailer Towing Package - weight-distributing platform trailer hitch receiver, 8-lead wiring harness with a 7-pin sealed connector (includes trailer brake control harness), heavy-duty transmission oil cooler and high-capacity air cleaner Keyless Entry System Theft-deterrent System / Ignition Disable / Alarm 98 L Fuel Tank Engine Block Heater Engine Oil Cooler 105-amp Alternator
The most useful information I made into a little graphic card I printed, laminated, and keep in the glove box. It beats digging through the 600-page owners manual for information.
Front
Rear
For complete details on my truck, please see:
My Chevy Silverado 2500HD Standard and Optional Features in:
Adobe PDF formatMicrosoft Word .doc format
My Chevy Silverado 2500HD Specifications in:
IMG_8385.jpg Load label for the factory-installed trailer hitch. Notice also the 7-pin wiring diagram moulded into the cover - nice touch.
IMG_8458.jpg GVWR sticker applied to driver's door jamb.
Sticker gives GVWR, GAWR - front, and GAWR - rear information, along with tire size, rim size, and tire pressure information.
IMG_8467.jpg Inside the glove box is this decal that gives camper loading information, for use with slide-in campers.
RPO Codes
GM uses a 3-digit code, called an RPO (an acronym for Regular Production Option), to identify the options with which a specific vehicle is built. They are listed on a label or sticker called the Service Parts Identification (SPID) label. On late-model GM trucks this label is found inside the glove box. Some of the most famous RPO's are Z28 (performance package found on Camaro's) and LS1 (specific type of V8 engine).
By recording your RPO's and looking them up in a reference table you can identify the options with which your vehicle was built.
Most RPO's can be found in the following:
GM Regular Production Option (RPO) Master List (pdf file)
IMG_8466.jpg The Service Parts Identification (SPID) label found in my truck. This label includes other information along with the list of RPO's, including the V.I.N., wheelbase, paint codes, and vehicle model number.
Below is a file I made listing all my trucks RPO's and their de-codes, available in:
Microsoft Excel (xls) spreadsheet format, orAdobe PDF format
More Info
brochure_tn.jpg features_tn.jpg 2007 Chevy Silverado Standard And Optional Features (pdf file)
(Microsoft Word .doc format)
key_features_tn.jpg 2007 Chevy Silverado 2500HD Key Features (pdf file)
performance_tn.jpg trailering_tn.jpg summary_tn.jpg owners_manual_tn.jpg Excerpts from the 2007 Chevy Silverado 2500HD Owner's Manual (pdf file) - all the most important stuff- fuses & locations, replacement bulbs, fluid specifications & capacities, maintenance schedules, etc. Apologies for the poor quality scan.
Detailed Information
My truck as configured online
.tos_dmca_policy { text-align: center; }.tos_dmca_policy table { display: inline-table; width: auto; }.tos_dmca_policy table { display: inline-table; width: auto; margin: 0 10px; }
Terms of Use
Copyright
Privacy Policy
1 - 1 of 2 Posts
