1 - 6 of 6 Posts
Depends on year, trans, etc--they could be the same ECP/PCM, but the internal PROM will be different.
The PROM's are easy to swap.
Also, the injectors have different flow rates.
There is a little cover on the ecm, under that is the prom. (chip)
An '88 and '89 should have the same ecm, 7747. Just the prom is different.
On the 7747 ecms you can swap it, there are a few other ecms like that, most I believe are soldered in.
1 - 6 of 6 Posts
