1 - 9 of 9 Posts
I just recently aquired a running (but not driving) 74 CJ5 with the AMC 304 v8, and come to find out the 3spd t15 tranny maindrive gear is missing half the teath!:mad3: So here is my question, what tranny is a direct swap in for my weak t15? I read this thread which gave me a little info, but not enough. From what I gather a ford t18 may bolt up if I drill and tap some holes in the bell housing? Help Please!!:confused:
unfortunately i couldnt tell you if it is a direct bolt in but the t-18 is an awesome tranny, ive got one in my cj, maybe look into a t-19 out of a scout with a 304, they are similar trannies and may bolt up as well.
The T14 is an exact fit, but not as strong. I quickly destroyed a perfectly good T14 with a 360. I'm pretty sure the 304 wouldn't take much longer to destroy it. Previous poster is right, T18 is nice, but if you want cheap, you should be able to find a cheap T15 or T150 used. It's been a while since I've done any work Jeep related, but if I recall, the T150 should be just about the same length as your T15 if you also swap the bellhousings.
Why not just fix what you have there? Rebuild it, run it for a while, then sell it later on when you can afford an upgrade to something else. I am sure there is someone out there looking for a fresh rebuilt T-15.
Just don't break it in the meantime.
For a little less money you could get a NP435 which I have been running for about 10 years now and I love it.... Beat the hell out of it and she keeps on ticking.... Good luck
Discussion Starter · #9 ·
Well problem solved for now, found a cheap replacement that was freshly rebuilt, but for the future I have heard good things about the np435 have to start saving though so I can do it right! Thanks for the info guys!!
1 - 9 of 9 Posts
