1 - 12 of 12 Posts
I just got my shipment from Northern Tool.
All fo the Hydraulic parts are present and accounted for.
Uhhhhhhm, what do I do next???
That is one beefy hydraulic cylinder.
I also ordered the extra fittings just in case.
I could sure use some direction at this point.
Thanks
my cell # 257-9299
Originally posted by YellowCJ:
<STRONG>What cylider are you using? I am getting ready to put mine together, so I would be interested in what you are using.</STRONG>
Northern Tool PN # 904208-C161
Its a CHIEF 3000 PSI Cylinder
2" Bore
8" Stroke
1 1/8" Rod Diameter
3/8" NPT Fittings
Cost: $74.99
Wow I just posted looking for a spherical rod end to thread onto the shaft end of that same ram <IMG SRC="smilies/biggrin.gif" border="0">
Having a rod and would sure make it easier to mount that thing wouldn't it....
Whoops my ram is the lion model with the same dimensions not the chief <IMG SRC="smilies/biggrin.gif" border="0">
Lions Chiefs 49ers whats the difference <IMG SRC="smilies/biggrin.gif" border="0">
Originally posted by Rocktoad:
<STRONG>Wow I just posted looking for a spherical rod end to thread onto the shaft end of that same ram <IMG SRC="smilies/biggrin.gif" border="0">
Having a rod and would sure make it easier to mount that thing wouldn't it....</STRONG>
That would be nice because I cut the yoke off the shaft, cut off some of the shaft, and reweld it on so it would be nice to just weld on a female rod end instead.
H8.. I will give you a call.
Team *******
I just use a piece of 1x2" about 2.5 or 3" long and drill a 1" hole for all of my kits and they work fine. Want a few?
Bob Roggy's got all the extras you might be needin too. Rod ends etc.
I saw a post that incorporated a diff cover into the mount for the hydro ram, the steel (not cast) would make for easier weldin.
But get with Dean and he can do the weld on the pumpkin for you too!!
Cant wait!
Originally posted by TheLakeRat:
<STRONG>I just use a piece of 1x2" about 2.5 or 3" long and drill a 1" hole for all of my kits and they work fine. Want a few?</STRONG>
This pretty much what I have been using too.
Originally posted by H8monday:
<STRONG>Northern Tool PN # 904208-C161
2" Bore
8" Stroke
1 1/8" Rod Diameter
3/8" NPT Fittings
Cost: $74.99</STRONG>
i've been checking that same cylinder out myself, i'm wondering what the outside diameter of the body is, could you guess or if you got time i'd love a measurement <IMG SRC="smilies/smile.gif" border="0">
Hey at 4 and 1, I would have to disagree with you, but then again you might be a traders fan, which means you can't think rationally anyways..... <IMG SRC="smilies/thefinger.gif" border="0"> <IMG SRC="smilies/biggrin.gif" border="0"> <IMG SRC="smilies/biggrin.gif" border="0">
1 - 12 of 12 Posts
