21 - 40 of 101 Posts
Discussion Starter #22
Today, I tackled the unpleasant task of cleaning and degreasing all the the other parts I needed to do. I got rid of my parts washer last year, as it took up too much room for the few times it's used. I now just use a big bus tub when needed, and rinse with a hose. It works but, presents a problem with the tranny and tcase. So today I tried something new.
I do a lot of BBQ, so last year I ran a hot water faucet outside to my outdoor kitchen. Today I Hooked it up to the pressure washer and instant hot stream power washer. Worked the nuts.
All cleaned up
The Piratenite
lol, I did the same thing today but on the other end.
I uses a 2.5 gallon bucket with kerosene in it and my garage sink with hot water.
my pressure washer hooked up to hot water is badass.
Discussion Starter #25
I've got some new 9 inch brake parts. If you need anything let me know. Got a new master too. I don't think I'll be using any of it.
I have most of,what I need, but I know I need the rear wheel cylinders. I'm good on the master, I picked up a dual conversion kit.
Discussion Starter #26
The pressure washer with hot water was very impressive
Discussion Starter #28 (Edited)
Planned on getting the rear axle together and painted, but ran into a problem. When I tighten the pinion yoke nut, the yoke gets to hard to turn.
I'm wondering if I have the wrong pinion seal. It seems the raised lip on the seal Hits the dust shield on the yoke.
Anyone have an ideal?
After this I thought I would paint and imstall the Ross box. When I start fiddling with it, something doesn't seem right.
The tube, and the shaft are bent. :shaking: And my other Ross box has a broken ear on it. So I pulled the shaft from that one and made one good one.
Discussion Starter #32
Well if I'm going to wheel the 3A, I figured it was time to replace my homemade driveshafts.
Discussion Starter #33
Like Nofender said, It's humbling working on these old jeeps, A simple pinion seal kicked my butt this week. Ends up that, the seal was in correct, buts it a newer style and does not fit with the pinion dust shield in place,
I had to cut it off, and I'm back on track
Discussion Starter #34
After pretty much getting the 3A cooling issue squared away, it was time to start thinking about the 3B. I have a pretty good start on parts for it, but still need some things, So During my morning scan of CL. I find a 54 3b, The ad has all the good stuff, rebuilt this, new that, runs and drives needs bla bla bla. For a real good price, figure there is more to the story, but I make the call and find out its pretty much as described the lady says. The main thing I am looking for is a nice tub, and a running engine, and soft top, and if those are true it's a good deal. It was about 2 hours up in Maine, and since I store my trailer about an hour from my house, I was looking at 3+ hours to get there, so I figured I'd grab the trailer today, and go up tomorrow.
I call the lady and she says she has gotten 7 calls since placing the ad this morning, and 2 people are coming in the morning. Change of plans, get the trailer and get up there. I get there and it's better than described. She bought it 5 years ago from a guy who just rebuilt it, everything but paint. Axles, trans and TC, all look to be rebuilt, frame is mint, better than the good 3b frame I have here, soft top is new, Tub is a replacement tub, With the slightest surface rust starting to show.
Then I get the icing on the cake. The lady goes "oh, and I forgot, it has a new engine." 😛 She goes on to explain, that 2 years ago, she was having overheating issues, so she brings it to her mechanic, who can't find a problem with the cooling system, so he pulls the engine to look into it. He does not find the cooling problem, but finds a crack on the block. So she said she got a new rebuilt engine, so I figure it has to be better than what I have. The Cooling problem ended up being the fan.
I get it home and look through the paperwork, and she bought a complete fresh rebuilt engine from these guys! MDR Engines - About Us Who look to be the real deal! I might even still have 1 year of warranty left😊
I am so pumped, even has an OD, It has some bubba issues. Like an electric fan, and fuel pump, but nothing I can't undo.
I going too look at it closer this weekend, but I'm thinking I will use this as it is, as a build platform. Might not even paint it, It's black primer with some surface rust...I kind of like the look.
Discussion Starter #39
I have the tacked together tub, 2 sets of good fenders, mint windshield frame, grill and 1 set of fiberglass fenders. Those all go together for $600. I have the f head of unknown cond, that's free. I have the front and rear axles front is complete, rear is missing hubs all brake stuff. $100 for the 2
Discussion Starter #40
This thing is clean, The seller said there was a problem with the front end, it pulled and drove strange, which I confirmed when I drove it...found one front hub locked.
Bonus, a Warn OD
It also appears the builder had a bug for metal work, he made little things like the battery box and a cover for the fuel tank.
