What about the wiring up in the fender? Doesn't the mud affect it. I think I am going to try and save the plastic inner fender at least for now cuz of the wiring. My aux wires for the lights and stuff goes through up there.Forget about the plastic liner. You're going to end up ripping it out anyway. Worse part about not having it is the mud slinging into the door jamb.
View attachment 3128269 View attachment 3128269
Lookin good. I dig your truck. Any reason on setting toe at 1/4”? I’ve always done 1/16”-1/8.”Another pic flexed and almost on the bumpstop.
Not a tremendous amount but hopefully enough. Although, it is more than the pic shows.
Oh, and I put those jam nuts on the tie rods and aligned it. It is at 1/4" toe in.
Thanks.Lookin good. I dig your truck. Any reason on setting toe at 1/4”? I’ve always done 1/16”-1/8.”
I don’t think you’ll notice much in handling, might hold a straight line easier without wondering as much. I think if you drive it on the road a lot you’ll notice a little bit more tire wear.Thanks.
Well, I am new to it. And I was tired of the change it was making going from jackstands to on the tires. So I settled at 1/4 thinking that is acceptable. Maybe, I should get it closer to an 1/8th. I drove it on pavement up to 35, and it seemed good. But I haven't slammed on the brakes yet. I would like it to be stable while on the brakes hard.
Hey, that sounds good to me. And really, it won't be on the pavement that much, only back roads to the mountains.I don’t think you’ll notice much in handling, might hold a straight line easier without wondering as much. I think if you drive it on the road a lot you’ll notice a little bit more tire wear.
Thank you for the compliment earlier, by the way.16 gauge is a lot thicker than the body. You're going to fight it more than a thinner piece.
