1 - 2 of 2 Posts
(2003 wrangler 6cyl 5spd 40k miles)
:jeep:
ok so i have this bad clunking noise when i hit bumps at low speed and if i really nail something like a pot hole at high speeds. i have jumped up and down on the bumper and pulled and tugged on every part under the frontend and nothin! Finally yesterday i grab the front drive shaft and BINGO! it was really moving around a lot! up at the CV joint or whatever that is with the 2 u-joint it was really shaking around. cant tell yet if it is the u-joints or if there is a bad bearing or something in the t-case. is there a common problem there???? would that be my clunking noise????? does that drive shaft ever spin in 2wd????
yes your front shaft spins all the time. you probably have a bad u joint.
1 - 2 of 2 Posts
