1 - 7 of 7 Posts
I've got a 2002 cadi lq9 6.0 motor and I'am having trouble getting the clutch fan off. I was wondering if anyone new if it was left hand thread or not. I've made a spanner wrench that fits in the holes on the pulley and been heating it with propane and trying to get it off both directions to no aval. I need to know which thread it is for sure! I'll be breakn out the torchs tomorow! Any ideas or thoughts welcome.:mad3:
the best thing to use is a air hammer with a chisel bit. I believe those are right hand thread. It would say "left hand thread on fan clutch" on the shroud if it was left hand.
The air hammer trick works every time, spins off real easy after the air hammer breaks it loose.
new question what do you do to keep the water pump pulley on after you take the fan off? is it a commin thread ,just get the right nut at the hardware or cut part of the old nut off the clutch fan assm. and use that?
1 - 7 of 7 Posts
