1 - 2 of 2 Posts
Here is my current dillema. I have a 79 with 20r and 4spd. I pulled into the driveway the other day, went to throw it reverse to park and noticed my clutch pedal seemed spongy and the trans wouldn't let me out of reverse. Then I lost my clutch. I grabbed the clutch fork and noticed the Slave cyl was not holding pressure. I could push the rod into the cyl w/ ease.
Now I have had problems with my slave cyl. in the past, so I went and picked up a new one. I also bought a new clutch master cyl. at the same time. Came home and put them both on. I bled the system and tried again. When you bleed the system the clutch builds a noticable pressure in the pedal. But I can pump it 8-10 times with system bled and can still push in slave cyl by hand... <IMG SRC="smilies/confused.gif" border="0">
The line from master to slave cyl looks good.
Totally confused. What can I be missing?
1 - 2 of 2 Posts
