1 - 5 of 5 Posts
I had a 22R and made mounts to run a York compressor. It could air up the tires real quick but blew loads of oil that needed to be filtered. Plus it was bulky and heavy.
Now I have a 22RE and the brackets I made for the York don't fit. The truck has the stock AC pump.
My ? is; has anyone used the stock AC pump for air? How about a CO2 bottle?
I can locally get a 5 gallon CO2 setup W tank mount and regulator for $200. It can supposedly fill 10-12 35" tires from 0psi-30psi and costs $10 to fill. Worth it?
Here is what I went with.
http://www.okieweb.com/outbackequipped/home.htm
Same setup as the powertank powershot setup for less.
I also like that I can put it in another truck and go or if a buddy is broke down somewhere you cant get to, just take air to him.
If its there, you might as well use it. ;)
The factory pump isn't much slower than a York.
OOP's has a Powertank and and a/c pump. I think he's said they pump up tires the same speed but he uses the a/c for tires and saves the PT for air tools...
TRT2 said:
Here you go, the best price around...
I have the 20 gallon and really like it, have purchased the 10 gallon for raffle prizes, great size.
Regulators: $15.25 *** 150 lbs. will be standard ***
10# Aluminum tank: $73 *** BRAND NEW TANK with handle ***
20# Aluminum tank: $91 *** BRAND NEW TANK with handle ***
Shipping is $15 for a 10# tank and regulator, and $21 for a 20# tank and regulator.
So, you can get a NEW 10# aluminum tank and regulator for $88.25 + $15 for
shipping = $103.25. And those of you that want 20# tanks, your price is
$106.25 + $21 for shipping = $127.25. Not too shabby.
The regulators are 150 PSI Hi Flow CO2 regulators (will not freeze) and have permanent O ring.
Cramer/Decker industries, 1.800.752.4579
or e-mail Paul Cramer at [email protected]
Mention TLCA pricing.
I went here for the truck mounting bracket...
http://www.lhrservices.com/fire_fighting_equipment/extinguisher_brackets.htm
Thanks to Jody Potter for finding.
from http://www.pirate4x4.com/forum/showthread.php?s=&threadid=84702&highlight=co2
chicks dig AC. hey and co2 is portable to other rigs. just somethings to keep in mind.
1 - 5 of 5 Posts
