1 - 15 of 15 Posts
ford 5.0
Got a reader and it gives no codes but I know it should. Maybe missing a wire that goes to the reader connector or something??
The self test on the reader seems to work but no codes and the book doesn't say what to do with no codes, POS! <IMG SRC="smilies/wink.gif" border="0">
NO codes???? What do you mean no codes?
whats up B? Hope you find your codes..... <IMG SRC="smilies/smile.gif" border="0">
When are you home today?
I'v had my code reader do this to me also. I don't have a answer for you but if you figure it out let us(me) know. When this hapens a good shop quality reader seems to work fine. It doesnt make sence cause it works fine on most rigs just a few it won't. <IMG SRC="smilies/confused.gif" border="0">
Discount!
Silly question sucka, but do you even have a "check engine" light on???
If not, turn your ignition on and notice if you even get the pre check light to flash.
Jeff
Discussion Starter · #12 ·
Originally posted by dog walker:
<STRONG>Silly question sucka, but do you even have a "check engine" light on???
Jeff</STRONG>
no, but I don't even have a check engine light either <IMG SRC="smilies/wink.gif" border="0">
Originally posted by Brandon:
<STRONG>bout 5:30 is the plan unless the wife goes into labor <IMG SRC="smilies/eek.gif" border="0"></STRONG>
OHMYGOD. You mean there's going to be a 'little Brandon' terrorizing the 'con soon ? <IMG SRC="smilies/biggrin.gif" border="0">:
Congratulations. <IMG SRC="smilies/bounce.gif" border="0">
Sounds like a race to see who gives birth first.
Her with the baby, or you with the 5.0
no codes at all... even when you just turn the key to the run position? no power... probably a popped ECM fuse, or a bad/loose/no ground situation. When you get that figured out, you may need to replce the chips and/or puter.
Discussion Starter · #15 ·
Originally posted by FYRMAN.:
<STRONG>no codes at all... even when you just turn the key to the run position? no power... probably a popped ECM fuse, or a bad/loose/no ground situation. When you get that figured out, you may need to replce the chips and/or puter.</STRONG>
well the engine runs fine ??
Fuse? what fuse? <IMG SRC="smilies/smile.gif" border="0">
Remeber I wired this thing myself so who knows as far as that little connector goes (factory harness)
1 - 15 of 15 Posts
