1 - 3 of 3 Posts
so...do you guys set your static height in the middle of the travel or do you prefer more droop? more room for compression? ...what??? Im trying to decide what travel c/o to get that will fit in my packaging requirements...I don't need obcene travel and I think a 12" will be just fine...but there is something cool about a 16" travel coilover.
The ideal setup for me would be at static hieght for the coilover to be about 25.5" long...which puts a 16" coil over about 2/3's through its compression and mounted on top of the axle (versus the side which some people do, im not sure I like though....i prefer the tabs to be in compression not shear or whatever you would call it.)....what do you all reccomend?
All the shocks I set up, I set up for about 40% compression, 60% extension. If you want give me a call and I can help you work out the right spring selection for your application. As far as travel goes, it's up to you...
1 - 3 of 3 Posts
