1 - 6 of 6 Posts
I have an 03 wrangler with a 4" lift on it, all suspension. It is the roughest riding vehicle i have ever seen. I don't know what brand if lift it is cause it was there when i bought it but i'm guessing it's just a cheap one, but do you think some new shocks would help or would i be better off just buying some new skyjacker or superlift coils?
98 RHD TJ: 4.0L/AX-15/NP231, J54/RS9”, 38s, 57:1
maybe the springs havent broken in yet, but it sounds like you have stiff shocks. start out by replacing the rear shocks with softer ones. mostly because there is more weight in the front of the Jeep and that should even things out. or you could try putting poly spacers on top of the springs to soften it up. how easy does it flex? good luck.
I went out and got some part numbers off of it and it's a rough country lift. I know they are known for having some pretty stiff shocks so i'm going to try that. Any suggestions? I usually use superlift shocks but thought about getting some skyjackers?
1 - 6 of 6 Posts
