1 - 15 of 15 Posts
I'm a bricklayer and work in comercial work. We use big boom forklifts with axles that are just like those. Coarse our lifts aren't coil sprung they have hydro suspention. I've often thought about trying to get the axles out of one and putting under a trail rig. It would have super ground clearence,super low gears,four wheel steering and super super strong.
Interesting. Looks like a very low production vehicle, whatever it is. It's hard to tell without a side shot really, but I'll take a stab and say it's some sort of "off-road" military aircraft moving equipment. Low height, high weight. It seems to be cobbled together from different parts from different machines. I'm betting the front axle is the same found on a Cat rubber tired backhoe, or some other sort of slow moving implement. It also appears to have a cat power plant, and no brakes on the front diff meaning it would almost have to have planetarys and a hydro-static tranny. The 4 links seem to be off a semi's rear suspension, panhard bars or dogbone links (whatever the application) along with the front panhard on this rig (connected to 3/4" plate?!) The coils seem and links seem to be an afterthought for this diff, leading me to believe it's still a front axle out of a cat rubber tire hoe.
Wait a second, upon further inspection even the frame appears to be cat. You can see where the pivot would attatch to the frame for the front swinging suspension. (beside the oil filter) it's almost like somebody ditched the hoe body and built a suspension and body for a hoe. What's the back and side of the machine look like?
The bad thing with any diff that came in a zoom-boom or backhoe is the intended speed of the unit. They do not work well in higher-rpm environments. The zoom-boom already having large tires would make it even less of a candidate to whip down the highway with 35's on it. The back hoe diff may be a better approach since it does have 35's on and it does have the beef to handle 44's (or even 52's) in a lighter vehicle application. Never the less, when walking one of these for more than a few km's at max travel speed's the diffs get hot. This is all aside of the fact that they can easily weigh much more than 2000 pounds.
Discussion Starter · #12 · (Edited)
we have a winner. i was told that this is used in underground mines and it is made in conecticut. its alittle heavy as seen here and i do wonder about the lube for the diff and high speed but i see this as an excelant trail maintanance rig. some outriggers a welder and a backhoe boom. this could be used in narrow canyons (i think) to move large bolders etc. perfect fo a private ohv park.
It probably is a cat engine but it is not a CAT backhoe front axle because they use ZF not Spicer and that spicer axle probably has interal wet brake in it. I think it looks kind of cool. I wander what they use it for?
Discussion Starter · #15 ·
drive it in underground mines and it has a heavy lift hoist on the other side. the trucker did not know the actuall use
1 - 15 of 15 Posts
