1 - 15 of 15 Posts
how do you guys think it would work.
i was thinking instead of doing a shackle flip and custom rear leafs that i might as well 3 link the rear since i think it would be interedting how it would do and i have not seen anyone do it yet.
i was thinking of using 1 1/2 .250 wall dom sleeved with 1 3/4 .120 wall dom for the links and use bushings at the axle mounts and poly performance jimmy joints or some big heims for the frame mount. also a track bar.
and just fab up some adjustable buckets using 1/4 and 3/16 plate.
what springs though i was thinking some like pretty flexy 4 inch lift early bronco coils. and with adjustable buckets i could compensate for sag in the springs
what do you think?
Go for it. I use BC bronco's 5.5" springs. Flex much better than my old Wild Horses 5.5" springs.
what do you guys think about springs.
Do you think the spring rate for the frontend of a early bronco would be about what is needed for the rear of my 86. i think i will try it.
maybe i will try some 5.5 bc broncos
thanks for yor thoughts
Front
sounds like a great idea your links sound like they will be plenty strong and it will work pretty damn good. What about FOX airshocks????? probably be a little more then new coils but are relitively a cheap route to take.
Discussion Starter · #10 ·
with the lowered bukets and the springs hoe much lift did you get
i need 6 inches so i was thinking of some 4.5s
rokdog03 did you ever complete this 3 link? if so how did It turn out? I am about to head to SD to help my brother with his build up of his 80 bronco and I am thinking I am going to do the 3 link rear for him. I did it on my sami and It works great. Id just like to know how the 3 link does with the tall heavier bodied full size bronco.
let us know how it goes.......got a buddy wanting to do the coils and ford radius ars all around, on a cheby :D
I run WH 5.5 coils on the front of the Feep, good articulation......
Discussion Starter · #14 ·
no i ended up getting custom leafs made from alcan spring and running a sky manufaturing shackle flip.
try it i would like to see what i missed out on
TDbronco, sorry for the ignorance I am a sami man. On the wild horses rock crawler 3.5 thats 3.5 inches lift or spring type? On the rear 3 link I am going to do like you said with the 2.5 DOM for the link bars, but I have some good Jonny Joints that I have had only good luck with. I will use these on the frame and axle all around exept for the mounting point on the top link on the axle housing, this I will use a beafy hiem joint.
BUZZISCRAZY2 as for the radius arm all around; I am going to keep the front radius arms, but I will cut the drivers side and sleeve it. I have a buddy with a Rodeo with front radius arms alot like ford uses and we had to cut and sleeve one of them on the front for better articulation. This helps a bunch. I let you know how it went with some pics. I dont think he wants to go high or huge tires he just wants the max out of what he has. I will put some pics on here for u guys in feb when I get back.
Tom
1 - 15 of 15 Posts
