1 - 20 of 40 Posts
This is my first time designing a chassis or cage of any kind. Let me know what you think. :)
A few questions:
Is the "X" behind the seats need to be tied into the frame rails or is it alright where it is?
It seems there is a wide span from the A to B pillar, will that be an issue?
Blue = .120 wall 1.5" HREW
Green = .095 wall 1.5" HREW
One really effective way to build an ugly chassis is to have a straight B pillar. If the chassis doesn't taper in from the door bar up it looks boxy IMO. It's stronger to angle that section in rather than building a rectangle.
Maybe a B to B spreader at the door line. DOM in the high stress areas at least.
I am planning on the B to B spreader, but probably at shoulder height for harnesses.
x3 on using DOM. Id also like to see the rear down tube tied in to smothing more then that single horizontal tube and the green tube coming from the front really should hit the dash tube junction if possible.
The rear down tube will be braced up with a shock mounting solution. The hood bar doesn't meet the the door bar because I am using the Samurai hood and cowl. I guess I should go price some DOM. :(
Discussion Starter · #8 · (Edited)
The B pillar is angled in 7 degrees at the door bar and swept back 5". I may sweep it back another inch or two. Thanks for the suggestions.
Would like to see you rework or reinforce that area where all the tubes (should) come together at the A-pillar/dash, and the tubes running from the top of the B-pillar down to the bedrail tubes should also be tied-in to the chassis in some more direct fashion. Would also encourage you to think about suspension geometry and shock mounts so that you don't have to add those things as afterthoughts. Because, you know, that's exactly what they'll end up looking like.
Don't use the thinner wall tube on any tube that could come in contact with a rock in a roll over.
thinner tube can be used somewhere where dent will more than likely not happen as a dented tube can cause structural failure if you roll more than once.
It looks like its a pretty minimalist design so really ask yourself where the loads are going to go. Think about every weird roll over you have seen and then ask where will that load transfer. If this tube fails what else will fail.
That thinner tube might be cool to reduce weight but a cage is about protecting yourself. That and the fact it is HREW says no way on the thinner tube above your noggin
Discussion Starter · #11 ·
Thanks for the tips, that's why I posted this. It definitely needs more bracing and support in places. I might be able to cut holes in the cowl in order to tie the A pillar into the engine cage or front fender tubes. The suspension is all taken care of because I'm using a stretched Samurai frame and leaf springs. Nothing fancy. Wish I could afford coilovers and links. :( I consider it a "Formula Samurai".
Discussion Starter · #13 ·
I would not build anything out of .90 wall that will ever hit a rock or the ground...unless you like dents.
A chassis built from .90 wall tube would be indestructible! :flipoff2: I'm going to change most of the tube to .120 and only use .095 on small braces and non structural pieces. Thanks for the help everybody.
I thought the exact same think when I saw it.
FWIW..I did 10 or so paper sketches just to gets lines that flowed for my buggy.
Once I had a layout I liked, I tossed it in CAD and then adjusted it for sanity. Honestly, a good bender and a little bit of time will allow you to do compound bends. Make it look a little less boxy..
I would try to use DOM also. HREW is "soft".
Discussion Starter · #18 ·
Looking good ,
Is that the stock samurai frame , why not round tube frame?
I think you can have more options when you use round tube for the main frame rails
I'm hoping keeping the frame will speed the build up (I'm keeping the Samurai drivetrain). I have also already done quite a bit of work on the frame. It's stretched and the leaf spring hangers are flush with the bottom of the frame. It gives me something mostly square to work off of and is cheap.
Why because you have seen lots of buggys with round tube frames? :rolleyes:
It is so much easier to mount things to a nice flat surface. Samurai frames are actually really strong and are basically 2x4x.090 front to back without any crazy swoops or bends like some factory frames, and are much stronger then any piece of 1 1/2 - 2" round tube (talking a single run here like some people replace sami or toy frames with) Look up some buggy builds on here, It isn't uncommon for people to start with 2x3 or 2x4 frame and build from there. If I ever get around to "buggy-ing" out my sami this is how I will do it, I'll give you the fact that I will probably end the rec tube at the b pillar but IMO it is much easier to mount a motor/tranny/tcase, fuel lines, brake lines, leaf spring, skid plates and such to rec tube.
I would ditch the every last .090 tube that is on the out side, mostly the roof, "first" B pillar and door bar braces. I understand the light bar because its replaceable. Its not that much weight savings from .120 to .090 and .090 will dent BAD. Usually when you end up on your roof it isnt a soft roll :flipoff2:
Also up the sliders to .188 1 3/4" or so, If you don't have a die for your bender, I'm sure you could find a shop to knock out just the 2 pieces. I thought I could get away with lighter tube on my samurai, but I still bent the shit out of my 1 1/4 sch 40 pipe sliders (1 5/8 x .145) Which is waaaay harder to dent or bend then 1 1/2 HREW (not trying to start a debate here :flipoff2:)
1 - 20 of 40 Posts
