1 - 4 of 4 Posts
OK, flame suit is on. and I did a search.
Has anyone done a write up on converting the dually axle to a single?
I have found what I believe to be a Dana 70 (Can't find the numbers yeat), on an 1972 international 1210 pickup with a wrecker body on it. it is a dually and will need to be converted.
they are both right. the wheels will bolt right on and the lugs are longer on the dually. isn't a problem but when i put my dually rear in myh jeep the threads on the lugs were messed up close to the hub where the dual wheels ride. with just a single wheel the gurrewd up section came out far enough that the lug nuts wouldn't tighten all the way down. try it if it works the leave it but if they are messed up swap to the lugs for the same rear only for a single wheel application. like bullfrog said they are shorter.
1 - 4 of 4 Posts
