I see what you mean. I havent been able to get that to work outside of using ArcGis at work to edit the gps points. Otherwise it just shows as a solid line but your not able to edit the segments.Yes you can, but since the KML file is a few months old, it does not align properly like a current file does, but if I convert it to png then i can move it into the correct position.
