1 - 4 of 4 Posts
I know Jim Van Den (sp?) did this on his rear steer cruiser.
any good ideas on how he did it?
just rip the old ram apart and put another end on it???
Is it that simple?
you will be able to use some of the parts but alot will have to be re-made or modified.
The tube can be used but your ports will need to be changed.
You will need either a new rod or cut the old one depending on the length. The piston will have to remade or modified to accept a rod into both ends of it. You will need another end cap so the rod can come out both ends.
Have a look at a couple of exploded diagrams of both set ups and it will all become alot clearer
1 - 4 of 4 Posts
