1 - 5 of 5 Posts
I have already done it so if its too late then ooohhhh fawkin well.
my gear box had to be mounted so far forward that a good size chunk out of my core support had to be cut out to make the gear box fit.
I have seen several posts with pics of this but for some fawkin reason I cant find them on here tonight.
Anyway, if I didnt have to remove all of the brace for the body mount am I sacrificing too much strength in that area. We were gonna weld up some type of brace for it if it makes a difference but I thought I would ask.
I didnt know what kind of damage could be done if I was to drop on that side very hard.
Should we go ahead and weld up some type of brace or will it be alright the way it is??
Without actually seeing pictures of what you did, I'm going to say that you will be fine. A hard hit on a side will do the damage anyway, no need to worry about it. My roll last weekend took out the fender and the front clip, time for tube.
I'm going to do the same to mine. After removing my front clip from the 4runner to use on the Xcab, it's only 40~ spot welds at the cab and two body mounts holding that part on anyway. I don't see how it could be "that" bad. I might replace some of the cut out sheetmetal though just because. Here's VOVA's, I don't have a body lift either, so I assume mine will be worse.
That is the picture I looked for all god damned night last night and couldnt find it!!!!!!
Every time I would search anything involving axle forward or gear box I would get that pic. Last night, I couldnt find it for anything.
That is also "Exactly" what mine looks like right now.
We were gonna weld a piece from one side to the other on the body mount and a piece from the body mount to the support under the radiator and hopefully get that little bit of strength back if neccessary. If it isnt important then fawk it, I will just leave it be.
1 - 5 of 5 Posts
