81 - 100 of 104 Posts
wow, I never thought I would see the day, that people would say Gm sucks and the 14 bolt sucks because it was used for so long and has aftermarket support......that like saying LS engines suck because they can be swapped into anything and had lots of support.......
The SBC legitimately sucks and its only redeeming quality is support. The LS is a superior product and can actually stand on its own merits.
The 14b is in the middle. It's a good solid axle but it does nothing that makes it obviously superior to other axles of similar size, weight and price.
yes, the LS is the newest version of the SBF.
the only thing they fuked up on was the thermostat water flow, it is good that they kept the 351c head gaskets and water passages to allow for a dry manifold, but then they drilled it for steam holes??
it has to be embarrassing for all the chevy guys that chevy completely abandoned the sbc and built a sbf clone
ford guys have been saying that for decades
so why arent everyone swapping in coyote engines, or mod engines, or hemi motors? I cant tell you the last time I saw someone swap a 5.4/10/4r100.....but people swap a 6.0/4l80 all day long....
In KOH.....why is the LS the dominant motor platform......This is insanity.....things dont dominate the market if they dont have merit....
I will say, I would run a sterling 10.5 just as soon as I would run a 14bolt....esp if I had a super duty 60....i would not go out of my way to change bolt patterns from 8x170 to run a 14 bolt.
But I also have never seen someone make a sterling front axle, or 11.5 front axle.....dana 80/14 bolt rule that......for good reason IMO...
.things dont dominate the market if they dont have merit.....
so McDonalds is the best tasting hamburger, the absolute best food ever then?
the SBC dominated the aftermarket so it was the best engine ever? as long as they make sure the fords are rules restricted what with it being beat by 351c in every motorsport.
the LS is better then any previous sbc. that part is very true.
why dont people use other then chevy stuff? that part has baffled me for a long time.
the ford 6.2 motor with its factory 4.5 bore spacing and OHC should have a massive following, but it dont.
having lots of something doesnt mean its the best.
what racing does chevy use the LS? nascar? nope. the biggest US small block race series doesnt use a chevy motor.
engine masters challenger let the mod motor in to play once, and the three mod motors finished 1 2 3 by a landslide. I cant recall an LS doing well in the entire history of EMC.
merit has nothing to do with popularity. never has
The Modular family isn't popular for a reason. It's fucking massive. The V10 is as long as a 300 and wider than a 460. It would make an OBS F-series engine bay look small. The 6.2 is no better. OHC V8s don't get swapped into stuff because it's hell to swap into older vehicles whereas the LS fits into stuff easily. Because the Modular and 6.2 don't get swapped into stuff there is little aftermarket making it harder and more expensive to swap into stuff.
Ford also doesn't care as much about aftermarket as GM so they spend a lot less effort making stuff available to make things easy.
GM is definitely the McDonald's of the automotive world though. Cheap and readily available will overcome a lot of other flaws.
All the American Le Mans chevy's are running LS engines. They run with and beat the fancy euro cars.
As for NASCAR, I guess you've never heard of the RO7 chevy engine. No, it's not an LS, it's a race engine that's never been in a production vehicle, just like the Ford, Dodge and Toyota NASCAR engines.
oh I heard of it. thats the 2007 motor chevy got to run for a couple of years while fords were still limited by the rules to their OEM based engines, the fr9 was allowed to compete in 2009
can we drift further from the topic now or is this it.
chevy guys get all butt hurt when you say the 14ff and LS aint all that. amazing.
I'm not versed in the engines, but a Sterling is on a par with a 14 bolt for strength. The 14 bolt has been around forever, so the support is there. But the Sterling will probably take over the market because disc brakes and VSS. As mentioned, the pattern matching the Superduty 60 is a big plus. In fact, the Super 60 and Sterling will probably be the "go to" diffs in the future if not allready. I believe Rockwells are becoming obsolete. If you want stronger than a Super 60, go Axletech.
I wouldn't run an LS if it were free but the Savvy car has won the 4500 class in EMC I think 5 times.
And Yuge spindles/wheel bearings, with Yuge brakes. I'm out west in buggy land and know people running matched pairs of SD 60/SV10.25-.5's. You can pick up a complete pair for $600 bucks all the time while KP 60's which are not as strong still go for $1,000. The 05 up SD 60 is f#cking enormous though, and a PITA to cut the radius arm casting off the diff side.
Because everybody thinks the best bang for the buck is an LS engine. Even though the top 20 4400 LS cars now are all running engines that cost over $30K each and using LSX blocks that fix the top end priority oiling issue that plagues the stock ones.
Rolling Mod
1. That is the dumbest thing I have ever read.
2. You are talking about two different EMC’s. He is talking about engine masters which has dick to do with KOH.
3. The savvy jeeps have to run stock engines. So this is mental masturbation
Sorry, thought the "?" meant you wanted an answer. BTW, the RO7 engines are still running, they just have FI now as per the rules.
Not butt hurt.:flipoff2:
Safety third!
The Monobeam 50 was never great in it's day nor now .
I have yet to figure out why it exists . Seriously .
The ONLY benefit of a 50 is no carrier break, but who the fawk would put tractor gears on a 50 ? In a toyota okay, something with low power ? Sure...
Tell me it was cost savings and I'll tell you that the extra design/engineering/casting/machine work needed to create the MB50 more than negates the savings .
I would love to question the guys who made the decision to build the thing. It does make very little sense. The TTB50 made sense. But why not a fucking 60 instead of monobeam 50? I mean it's already pretty much there.
The 8.8 gears and carrier maybe stronger, but the housing tubes are paper thin and the design of the wheel bearings are completely stupid. I hate to be a hater because I own a Bronco with a 8.8. (I installed a truss and ful-float kit to solve the problems)
I had 35's on a Scout on Dana 44s. Zero problems. Not so on the Bronco.
Funny thing is they are rated for more load than the 9", with the thinner tubes. I love them for cars, they hold a lot of power and are lightweight. I love me a 9", but the hot drag racing rear is an 8.8" with 9" outers.
Nobody is saying the 14 bolt sucks. We're arguing it's place on the totem pole. Well, MJ mentioned he wouldn't run any part of one, but I doubt even he will tell you it's a complete shit option. Many of us just think it's been surpassed as the top dog in it's category, and from me, by both the modern Ford AND GM offerings.
I'm also saying aftermarket beefier parts are not an indicator of it being better from the factory. Aftermarket or custom parts can improve any part from any make.
And:
The LS engine was kept small and pushrod to fit in a Corvette. Ford has always had massive engine bays in Mustangs and they didn't really care. In many cases GM guys have entirely ditched their heavy cars for a lighter Ford, and Ford guys have entirely ditched their engines because the LS is what the Windsor would have been, had Ford not build that gigantic retarded 4.6 motor in the first place. My 460s are smaller and the one for my car is SBC weight.
Interestingly, Ford is going back to pushrod for their truck engines. The new 7.3 gasser should prove to be a drag strip favorite once they start ending up in the wrecking yards. There have been a few 6.2s, but take in mind, engines that aren't offered in performance cars have a harder time ending up on the drag strip. The Camaro and Mustang are what drove much of what you see now. I think the displacement factory will help this one along.
To expand, when Toyota was given admission to run in NASCAR, they were given a clean sheet redesign. Everyone else said it's only fair if you give us one. The Ford, Mopar, and GM designs are really fantastic engines that I'd love to have in a production car. It's basically why I can't watch NASCAR. It has no bearing on reality, despite being "stock car" racing.
Again, a lot of this is monkey see, monkey do. It's a lot easier to source parts for the engine that everyone else runs in a pinch.
LS isn't a bad engine, at all, but "the best?" Certainly not for everything. You gotta remember most guys with a wife and 2.5 kids and a mortgage are going to run what's easy and they can put together quickly with a lot of help. "Best" is exactly the same as "Cheapest" for a good chunk of potential buyers. This is actually why the 350 is still the most popular motor, despite the LS being so much better. At the top of motorsports, everyone is spending fuckloads of cash for whatever engine they run.
It does make me laugh how many chevy guys told me that Fords were too hard to work on and that's why they hated them in the 90s. Well, they are Ford of the 90s now, and they absolutely love it. :laughing:
I just get bored seeing them personally and have always liked having something different. Well, that and they don't have the torque curve that a BBC or a BBF does. But, it's easy to see why they are the most popular engine in motorsports. They took the best of what everybody had, put aluminum heads on it, kept it as small as a 302, and gave it the capacity of 427 inches like all of the other small blocks from the big 3. Modern metallurgy didn't hurt either.
Most importantly... it's at the right age to be cheaply obtained. 2 decades now, most of which is very well documented.
Google "37 spline 10.5". Go ahead.
I have never purchased a spool for anything, but you're missing that the carriers themselves are not strong enough on those little axles. A Sterling carrier is beefy as hell and isn't what's going to break.
That doesn't explain why they make them for the 14 bolt or 60, but some people want to ditch the weight and buy shiny parts I guess. For wheeling, it makes no sense to buy one imo unless you just don't have a carrier with that free axle you got.
"No market" is the easiest explanation. You can find numerous posts about guys just welding them up on here. And again, with the 14 bolt mantra, nobody has bothered to make them. Nobody would buy them unless every mofo out there was using them. Who runs a spool in a 14 bolt anyway? Maybe pullers? Not really common in the wheeling world.
The hot money is on a 10.5 with a factory E locker. It does everything you'd want and needs no upgrades but whatever gear ratio you want. If 4.30s will do, some trucks get that factory.
I run a spool in a 14b
My bad, the letters EMC mean "every man challenge" to me especially since we're racing it in a couple days. The fantasy football of engine dorks isn't really on my radar.
The savvy rig I'm talking about is the 4500 car #88 and they run a 454 LSX in it (kicking our ass every time time it races). They've won the 4500 class 5 times with it, 13-14-15-16-18.
yes, I mean Engine Masters Challenge.
the one where an LS was constantly defeated.
this WAS a pure 'what engine is best' contest. they killed it of course as the results did not favour the advertisers or the LS.
I think near the end they had to give the LS its own class so it could win something, for 2019 it is call 'Extreme Street LS' class
the top teams would win just as much with whatever engine brand they stuffed in the chassis unless the rules makers started restricting engines to favour a brand. the top guys are all extremely driven people.
Does the #88 run a 14ff?
