1 - 3 of 3 Posts
What kind of push-rod travel are you guys getting for a corvette manual master cylinder and 4-wheel discs? I'm in the middle of setting up my pedals and space is limited. I changed my pedal ratio to 6:1 which is about as much as I can do. My new concern is push-rod travel. I'm getting a bout an inch of travel right now, will that be enough?
Discussion Starter · #2 ·
Ok, I'll add some tech here. I measured the travel with a bolt, marker and a tape measure and found that maximum travel of the piston is ~ 1.25" So, in my case I think that I should be ok.
1 - 3 of 3 Posts
