1 - 2 of 2 Posts
I am putting a NP-435 into my 4.0L YJ, Ihave designed and machined a bracket to hold the CPS on the new bell housing, The bracket bolts on using two of the stock BH bolts and the CPs mounts to the bracket and hangs inside the BH in the stock location.
The bracket that I made is steel, will this have any effect on the magnet in the CPS? In stock form the CPS bolts to the aluminum Bell housing and is nowhere near any steel except for the flywheel. Should I remake my bracket out of Aluminum and should I forget about it?
Josh
1 - 2 of 2 Posts
