1 - 2 of 2 Posts
I have a complete TPI system Speed density that I was going to install in a S-10. I also have a crate engine with roller rockers and R/V style cam.
The TPI is powder coated white, it has a adjustable fuel pressure regulator rebulit injectors 19 lb prhr, after market chip with the VATS and I/M removed and no speed limiter. Harness is already modified and ready to be installed. Comes with HEI dist also.
The crate engine was removed from a farmers truck that had 8000 miles on it His daughter ran into a poll and totaled it. My brother inlaw took it apart and installed new bearings/ rings and had the heads checked installe the cam and roller rockers and had planed on using it in his CJ but plans change and I ended up with it.
I also have all the accy for the front of the engine, alt/p/s pump, a/c compressor all the brackets etc
Drop me a line if you have any questions.
$1500.00 obo
Will seperate and ship if needed
In Utah 84660
Dan
801-592-4319
[email protected]
1 - 2 of 2 Posts
