1 - 5 of 5 Posts
you could make it work. i would set the axle up. find the center of the pitman arm and measure how long you need your tie rod to be. all i did was get to ends that worked and find nuts for them. get some circle tubing and weld the nuts to the end of the tubing and put your ends on
1 - 5 of 5 Posts
