1 - 6 of 6 Posts
Dinkerdoodledoo
Major paradigm shift here.
I don't want crimes. I'd prefer to do something else.
Camo calls favors from Vendors Bro-deals.
So instead of Crimes, I want Bro-deals.
An example:
You contact Phil at Silly Fab for a hook up on a new roll cage for your rig.
Success would be: Phil installs a pimptastic cage into your Jeep JK, worth 5K (blah-blah)
Failure would be: "Sillyneck chases you outta his shop on his motorcycle with goofy rear sprocket while wheelie-ing at 4mph, chucking hot dogs with relish at your noggin."
spend 20 mins in the Band for attempting to be cool.
Come to think of it, I don't want fights. Everything will be a rig-related challenge of some sort.
Might make the game mechanics easier.
Lurking since 1956
An example:
Not a shift, I'm way ahead of you:D There will also be something like that for the rigs. You will battle head to head with your rigs.(attack) but it is a grudge match. Also, the trail rides, if your rig breaks and you don't have the schooling to repair it,the rig will be impounded for so long. edit: that is if you're happy with this?
Lurking since 1956
There will also be pro competitions for the higher players with highly modified rigs. There will be 4 classes of rigs. parts(armor/weapons) for one class rig will not fit on the other classes unless it is a custom weapon(armor/weapon).
Lurking since 1956
Oil will be the item that will be the most sought after med, it's the one that will restore all stats after a move. It will be one of the items in your donator packs.
Lurking since 1956
BTW, we have renamed all, well most of the stats to refer to something with the rig. oil pressure, compression, mileage, etc
Dinkerdoodledoo
Discussion Starter #6
I noticed.
1 - 6 of 6 Posts
