1 - 3 of 3 Posts
I have a YJ that will soon undergo an SOA conversion. It has a Waggy 44 up front and I plan to go with a cross-over steering setup. I'll probably use a stock pitman arm and I plan to use the RE 1.5" SOA springs (the ones with the reverse eyes). Can I expect the drag link to clear the springs using just a high-steer arm mounted on a flat-top knuckle? Or should I expect to have to use a spacer between the arm and the knuckle?
Thanks,
Roger
1 - 3 of 3 Posts
