Socal, i built a crossover on mine. I dont really have any good pics of it. Let me know if you need any details.
I was at Rusty's a few months ago and saw his new crossover setup. I really liked it. For the nuckles he machined these pieces that slip down into the nuckle and have a misalignment spacer at the top (picture a mushroom, the stem has splines on it and you tap it down into the drilled out nuckle, then the head of the mushroom is the heim spacer that sits atop the nuckle allowing bind free heim movement. This setup would seem to be a lot better than what i and many others have done. We drilled out our nuckles to take a 5/8" bolt and 5/8" bore heims, using a separate misalignment spacer ontop. The problem with this is that the bolt usually ends up boring out the nuckle and you have to ocasionally tighten it to ensure that theres no movement.
Rusty's kit also comes with a new weld on above axle track bar bracket and new weld on sway bar brackets, since your stock ones will have to be cut off to clear the drag link.
